Re: Transformer Article 450
bwyllie:
Your right right! I just looked in my 1999 handbook and found it.
"Section 450-13(b)continues to permit the installation of dry-type transformers rated 600 volts or less and not exceeding 50 kva in hollow spaces of hung ceiling areas, provided these spaces are fire resistant, ventilated, and accessible". It also goes on to say that it,s ok even if it,s used in a space used for enviromental air provided the transformer is in a metal enclosure.
Russ
[ June 21, 2003, 05:54 PM: Message edited by: russ ]
