transformer breaker sizing
a.bisnath
Electrical worker
a single phase 15 kva transformer 440 volt primary 220v\volt cetre tap secondary is being set up for a garage small power and lighting supply I wish to carefully size the in and out breakers to avoid overloading/heating the transformer .May I ask for a practical opinion how you would do this?Also this will allow me to design the garage layout with the allowable loading(amperage) in mind,it is a short run of 25 feet so voltage drop is not an issue.
440V and 220V as well as your spelling of centre, lead me to believe your garage is not subject to the (US) National Electric Code.
