Eddy Current
If i have 480V on the primary and 240V on the secondary that is a 2:1 ratio. What would i get if i had 120V on the primary? The book i am studying says 20V but wouldn't it be 60V? 120/2=60.
And the name of the book you are studying and the associated math is.....?
Was this an example calculation?Delmar's Standard Guide to Transformers
I can see no explanation other than a typo to justify an answer of 20 volts.
Lowering the input voltage cannot do anything to change the voltage ratio.
But increasing the input over the design voltage can destroy the transformer as well as result in an unexpected output voltage.
That's what I get, yes.Yeah an example calculation. It should be 60 right?
