Hello
I am trying to add another load to an existing 480V 1200A Bus MCC. The MCC is fed from an 480V 750kVA transformer capable of supplying 900A on the LV side to the MCC. I have added up my connected loads to the MCC and noticed that the total connected load is somewhere around 1050A. However when I monitor the ammeter on the tranformer LV side, we are only drawing about 300A max during normal operation. There is a 1200 A breaker feeding the MCC from the transformer rated for 1200A but dialed down to 900A.
I was wondering if there was some sort of divirsity factor that allows for a connected load to be more that what a transformer is rated for. Does anyone know anything or is there somewhere in the code that explains the connected load and divirstiy factor? Would my connected MCC load have to be lower than the 1200A bus rating regardless? I am looking to find out how to calculate the divirstiy factor (if avaliable) or what the max connected load I can have on the transformer is.
Seperate but quick question: Is a magnetic instantaneous molded case breaker capable of interrupting a ground fault. Does the breaker trip on the magnitude of the gnd fault flowing through the faulted feeder in the breaker.
Thanks
Mull982
Thanks
Mull982
