Re: Transformer Connection
I cannot tell from your description, without having a wiring diagram in front of me, whether (1) You have the correct voltage at each of the secondaries, and (2) You have the three secondary windings 120 degrees apart from each other, and (3) The phase rotation (A-B-C) is correct. But if you do, then the result will be indistinguishable from the intended result. Selection of any given phase as the "reference phase," and selecting a point in time for that phase to be at the "zero degree reference point" are both arbitrary. What matters is the relationship among the three phases.
