curt swartz
- San Jose, CA
- Electrical Contractor
Yesterday I received a shipment of GE150kva 480-208/120 transformers for a project I?m working on. My supplier told me they would be either GE or MGM so I made sure the conduits were installed in the slab so they would work with either one. I noticed through the front went what appeared to be a terminal strip with quite a few very small wires attached. I decided to pull the front panel off and directly behind it was a 400 amp molded case shunt trip switch. Then I looked down to see 6 fans at the bottom right where my conduits are located. Luckily the conduits have only been installed for one transformer so far and they will now have to be run across the wall. I don?t install that many transformers but this is first time I have seen a small dry transformer with fans. Are others finding cooling fans a common item in the newer transformers?
Happy holidays to all!
