rookie4now
We have a 1-line for an upcoming instillation that shows a 100A 3P breaker feeding a 112Kva transformer, then after the transformer is a non-fused disconnect and then a 100a 3p panel that has 3 3a 3p breakers for the equipment. The distance between the panel that is supplying power and the transformer is about 50' and is in another room. Won't we be required to put a non-fused disconnect on the supply side of the transformer AT the transformer? Also, shouldn't the disconnect between the transformer and the sub panel be fused? I suppose alternatively we could use a main breaker in the sub panel.
Also, any code references would be appreciated. I looked at 450 and couldn't find the requirements.
Thanks
Thanks
