Nickarus
- Olathe, Kansas
At some point in my education, I believe I read NEC Section 110.58 and burned into my memory that ALL motors and transformers should have a disconnect/breaker located on the primary/supply side of the equipment within sight, for safety reasons.
I realized this week that that section is specifically for "Tunnel Installations over 600 Volts, Nominal" (the header for this section - doh!).
That said, my current understanding is that transformers do not require, by code, a disconnecting means on the supply side within sight of the transformer.
HOWEVER... Is it still a smart idea from a safety perspective?
When a transformer needs servicing, perhaps it isn't a big deal to find the disconnecting means elsewhere in the building... but do transformers fail in dangerous ways that would make an electrician think "WHERE THE HECK IS THE DISCONNECT?"
Thanks in advance =)
