charlie tuna
- Florida
steel office building - law firm buys a new ups system and requests us to install a 100 amp single phase feed to their computer room to serve this unit. the supply voltage to the ups system is 240 volts. we connect the transformer as recommended by the manufacturer for a single phase - 240 volt secondary (primary is single phase 480 volts). the transformer has a welded ground lug common thru the housing. we have installed bond wires on the primary and secondary feeders and secure them thru the use of a dual lug connected to this welded lug bolt. on the common welded bolt on the outside of the frame we connect properly sized ground wire to the steel frame of the building.
problem and question: since we connected the transformer straight 240 single phase - we do not have a center tap connected to the ground lug of the transformer - and this makes this an isolation transformer - ie - we have no voltage from either 240 volt feeder legs to ground. is this correct or do we need to provide this center tap inside the transformer even though we have no use for it? and will the ups sense this???
