I received a building department comment that exactly reads:
It appears that an equipment grounding conductor from the transformer to panel ?K1? is sized per 250.122. The transformers are separately derived AC systems and the transformers have a grounding electrode system installed per NEC 250.66 & 250.30.
Situation:
I have a 112.5 kva transformer feeding a 400A MCB panel. I am using a parallel feeder of (4) #3/0 and (1) #3 EGC to feed my 208/3 panel from the transformer. I have a detail that shows a ground bus in the transformer, the ground bus has a GEC sized per 250.66 ( I used a 2/0) and coming out of the ground bus I have a EGC which is the #3 which goes to feed my panel. My detail also shows bonding jumper etc etc.
I think he wants me to run a 2/0 GEC to the panel if I am reading him correctly, am I missing something here? Is this correct??
Situation:
