Transformer Ground Size
mstrlucky74
NJ
How does one calculate the size of the ground wire( where in NEC) from a 75kva transformer to a ground bar? Thanks.
mstrlucky74
NJ
They are calling for a #2 GEC from xfrmr to ground bar according to transformer schedule. I've seen that size before so not sure about the 3/0 or #500 you guys mention. I tried referencing the code sections you mention but it was a bit confusing and referred me here and there.
infinity
New Jersey
Journeyman Electrician
Don is referring to the common grounding riser connecting the ground bars together.
