Is the primary of a transformer required to be grounded through an equipment grounding conductor if the secondary is grounded with a grounding electrode conductor and the secondary also has an EGC?
It is needed for there to be a path for short circuit current back to its source (via the N-G bond at the service) in the event a fault occurs in the transformer or downstream.
