What is the correct thing to do in the following scenario. Installing a 15kva Delta 480 3 phase pri. To a wye 400 3 phase sec. The Transformer will be feed from a 277/480 Load center. The building has wood post frame, so I can not cad welding the ground to the building structure. Do I install a ground rod for the grounding electrode of the secondary side? Or would that not be correct?
