wirenut1980
- Plainfield, IN
Hi all, first time posting here! I am 2 years out of college and still relatively new to the "practical" side of electrical engineering. I have a pad-mounted transformer, 11.5 kV-208Y/120 V. The grounding was installed as follows: a grounding conductor connected from the incoming primary cable shields to the enclosure grounding lug in the primary section of the transformer. In the secondary section of the transformer, the neutral is connected to a ground rod, and the transformer enclosure is also connected to this ground rod via another lug in the secondary section. My question is this installation NEC compliant? Or should a separate grounding conductor be run from the primary ground lug directly to the ground rod? Thanks!
