Gerry de Pedro
Why is it , for switchgear used as sevice equipment, wherein neutral and equipment groud are bonded,that you have to provide grounding electrode conductor connected from the ground  electrode to the service equipment ground bus or neutral ground bus while another is to be provided at the Transformer neutral at Y-secondary side since the neutral of the transformer is already bonded to the switchgear bus thru the Neutral conductors? Is this for testing and security purposes that just in case  that one equipment grounding conductor opens , you still have another one?
