wcollinge2000
I have a question about hooking a transformer 12,500 to 480. It is a 2500kva and they want to hook a blower to it so it will be 2880 kva. well all the switches are full there is a 1000 kva transformer that they(company) wants me to connect to the switch . there is #2 going to the transformer now . they want me to hook and just make the fuses bigger like 180 amp now I know that I can increase the fuses as per 450.3 tables and other articals like 240.100. there are others but as the 1000 kva has been in service quite some time and the secondary conductors go more than 25 feet . none are fused until they get to the different mcc's on different parts of the bldg. some do exceed 100 feet all together they way exceed 100 feet in artical 240.92 This is a company that falls under this artical. what is recommended I feel that we need to up size the feeders to the 1000kva to the size of the fuses I also look at artical 90.1 b I feel that they are going to try to make me leave the wires the size they are and will try to add to the larger transformer later the load at present that will be connected to the larger one is 958 on the secondary . now that is at present I know that they want to add atleast 1800 more in the not so far future . It would not be fully loaded but there going to push the limits eventually. now this is all continuous load. motors. there is no duty reduction at all none in the plant say for maby two 5 hp's that have a mechanical restriction from keeping them both running only one of those but that does not pertain to this question. Is there any other articals that are relevant. I have 210.19 ,20,215.2 ,3 220.200 230.200 and the ones in the 450's to me it just doesn't seem right to beable to fuse the wires at such a high ampacity or am I reading into it wrong . I believe that I can go to 150 amp without changing wires to the 1000 kva but that seems to me way out of wack. or am I missing some articals some advice this is the first time working with this and I am not really sure I just don't want to do it wrong. thanks
