Jerry Hill
My transformer theory is very weak. I have a transformer with multiple primary inputs. This transformer is out of a discarded 0-60V 1.5A bench power supply. I want to use it for a battery charge, discharge and test system in my shop. The bench power supply came with a feature to use it with selectable VAC inputs, i.e. 100, 120, 220 & 240 VAC, therefore there are several primary inputs i.e. wht 0V, blu 100V, yel 120V & gry 0V, grn 100V and red 120V. It also have 2 pair of taps on the primary side marked as 8V on both. The secondary has a yel 0V, org 15V, wht 35V & a red 64V. With a 120VAC input on the wht 0V & yel 120V primaries I get the desired outputs. I also get a 120V voltage reading on the second primary. Can this second primary be used as a semi-isolated source for controlling timer relays?:-? :-?
