mshields
- Boston, MA
If given the kVA and the percent impedance; say 112kVA @5% impedance, how would you determine the actual impedance in ohms?
Note: Actual problem I'm looking to solve is: I need to provide step up (from 208 to 480V transformer for x-ray machine for which the minimum line impedance needs to be less than 120milliohms.
So even after I determine what the transformer ohms are, if that plus the negligible ohms in the line less than 120milliohms, am I good. Or do I have to worry about the 208V line as well back to the utility transformer?
