Transformer Impedance
tryinghard
California
What would be a common impedance percentage of a 480-120/240 112.5 KVA cu wound dry type transformer?
I want to calc the available fault current without calling the manufacture, at least get it close for design purposes if I can.
I'm not purchasing just designing, our purchasing will have to call and it's not likely going to happen, I don't know who they'd use. Otherwise I agree I'd call.
I have a 83 KVA calculated load and there's no way I would buy a transformer without giving the site specific spes to the manufacture.
If you wind up being close on the AIC, I would bump it up. It kind of depends on what you are doing with the source impedance.
You could always call 2 or 3 manufacturers and use the worst case.
Transformer Question
The System Discription:
Need to provide 480V/3ph with less than 160 milli-Ohms of resistance.
The installed system
Building service = 120/208V 3ph 4w --> 75KVA X-former (5.11% @ 170C) --> 480/277V 3ph 4w
I am measuring 11 m-ohms on primary side & 261 m-ohms on secondary.
What %impedance do I need to achieve < 160m-ohms?
Will a 112.5 KVA X-former achieve this?
Do I need a 150KVA ?
