gary hoffman
- bellaire ,ohio usa
i am a residential electrician . i also have commercial experience. i own a building and i am installing a new elevator. the old elevator ran on 3 phase 3 wire 208, the new motor runs on 3 phase 4 wire 480, i need a step up transformer to achieve the necessary voltage .. the 208 is going to be on my primary side , the 480 volts will be on the secondary side... the elevator company said that ithey need 4 wires to feed their breaker for for the elevator. i am only feeding the step up transformer with 3 phase208 3wire how do i obtain the 4th wire on the secondary side?? the maximum load will be around 46 amps. i figure that a 1 kva transformer
rated at 100 amps will be enough.. can you please help me out???
