Toros
- Tujunga, CA
Hi ,
i have to design a power distribution system to a new tenant moving , in an existing commercial space (a shell-designed space)
all equipment in the new tenant space will be new.
note that, the main 480/277v electrical switch gear in an dedicated -small electrical room is existing with spare tenant main OCPD.
in order to step down that voltage to 120/208v, 3 ph. , i am using a step down transformer,
QUESTION IS ,
can install that transformer and its primary disconnect means inside the tenant space ?????
I do not fully understand the tap rule
Thank you
QUESTION IS ,
Thank you
