We have numerous 12,470 and 4,160 volt to 480 volt transformers that we need to maintain. To get the oil sample we have to open the energized secondary 480 volt cabinet on the trans. to access the sample port/valve. The exposed hot terminations/taps are only 1 to 2 feet away from the electrician when getting the sample. Does this procedure require arc and shock gear while in this energized transformer cabinet per the NFPA 70E and or OSHA?
