I am working in an industry where my technicians have to short the bus bars on regular basis (manually) for some maintenance purposes.
I want to add high neutral grounding resistance to the incoming supply transformer to limit the Line to ground fault. Presently the neutral has been solidly grounded. What will be the disadvantages of high resistance neutral grounding?
We are using neutral for some (single phase) welding and grinding purpose.
Can I have res in K ohms. I do have earth fault relay
