daveselectric
- Ohio
I am working on an older home that has an old "Jefferson Transformer" " Heavy Duty 75 Watts" which is used on the old style butler's notification system. The house was built in 1922. I can presume that the transformer has been in place since then.
The primary side is 110v.
The secondary side has three terminals. The transformer has the following embossed markings:
1 - 2 6 volts
2 - 3 14 volts
1 - 3 20 volts
There is an individual wire on terminals 2 & 3. There is a grouping of multiple wires on terminal 1.
I am about to replace the panel box and need to replace the transformer.
Has any one ever worked with such a transformer and enunciator system? Does anyone know where I can obtain a replacement transformer?
Based on the configuration described above, what are the wires going to the terminals?
1 - 2 6 volts
2 - 3 14 volts
1 - 3 20 volts
