How can you tell if a older transformer is overheating or getting ready to fail? I have a 225kva 480x208/120 dry transformer in a electrical closet. It is labeled as a 80deg rise. Using an infered camera i get readings of 240deg F. when looking at all 3 windings. The problem is it is only about 1/3 loaded. The air at the top near the vents is about 185deg F. This room has no real ventalation but i would expect a 80deg tx partly loaded to not be giving off much heat.
