holysmart1
- Michigan
- Controls Engineer
I am trying to understand proper transformer grounding. I have a single phase 480v to 120/240 volt transformer. The secondary side neutral is bonded to the ground on the secondary side, which is bonded to the ground on the primary side. Is this grounding correct? Wouldnt this make the primary ground a current carrier since it is tied to the secondary neutral? Or am I completely misunderstanding how transformers work? I will admit my knowledge of transformers is lacking a bit.
