TheElectrician
- New York, NY, USA
Hey Guys,
We have a Solar system installed with the following specs:
- Voltage: 480 V
- Current: 1080 A
This is fed into the secondary of the 1000 kVA transformer with 4kV on the primary whose spec. is:
kVA= (1.732 x 480 x 1080)/1000 = 897.895 kVA (1000 kVA is used)
From this the primary current will be:
I = 897.995*1000/1.732*4000 = 129.6 A
The POCO asked us to use a 2/0 wire for the primary, but I wanted to verify this so, Can someone please provide a step by step process to calculate the conductor size for the primary according to NEC?
Thanks in Advance
- Voltage: 480 V
- Current: 1080 A
Thanks in Advance
