Hello
I am trying to understand the range of variation in the primary side voltage of a step up transformer. For instance , a step down transformer with 33kV as primary voltage nominal voltage . What range of voltage (+/-) variation is acceptable in terms of % ? Ignoring the effect of variation on seconday voltage on load side , what are the factor which limits this range? Is there any standard which says that the voltage should not vary within (x%) on Primary side( HV side in our case)?
