wperdue2
New member
- jarrettsville, md
Hello,
I was wondering if there is a fault on a secondary feeder or branch circuit supplied from a transformer, can it trip or blow the fuses or breaker that protect the primary?
for ex if it was a 277 480 primary then 120/ 208 secondary and there was a phase to phase fault on the secondary.
I believe the protection for the secondary ie the panel main/ disconnect/ fuses it feeds would blow first or trip.
Since a transformer only works from mutual inductance between the coils there is no real "connection" between the primary and secondary coils I dont think there would be a path back, only on the EGC, but I was told about a 20 amp 277v lighting circuit that tripped a 1200 amp gear in a building. Come to find out that was because the Ground fault relay on the gear was set too low but it got me thinking about transformers.
Thanks
Woody
Thanks
Woody
