We have a substation 4160 pri. to 480v sec. that had a GF indicator light on the other day.We found that someone had made a mistake hooking up a 480v 3 phase motor, one of the phases was terminated to ground at the motor and the EGC was terminated to one of the motor leads,OOPS!I don't understand how the motor ran with no problems and nothing tripping.I was told that the transformer at the substation has a floating ground.Also when you measure voltage at MCC you get 480v between all three phases but when you go to ground one of the phases I believe it was B you get 0v.My boss doesn't have the time to explain so I was hoping you guy's could point me in the right direction,Thank's!
