PowerWagon
- USA
- Solar Contractor
Hello All, I haven't worked with transformers in PV systems that much so I'm a little out of my league here. Our client has an older Xantrex PV45208 inverter. As the name implies it uses 208 three phase with an isolation transformer. The inverter is going into a fault code 00000008 which the manual states is a ground fault on -B. I assume this means B phase. Since the grid goes through a transformer I'm not sure how to check for ground faults. In addition when I checked the voltage at the main panel I got 121VAC to ground as I would expect, but on the other side of the windings, Inverter side I get 111VAC, 92VAC and 133VAC. This doesn't look right. Anyone got any suggestions?
