Suyash599
- North Brunswick, NJ
- PV Design Engineer
Around here the kVA rating of the utility transformer is usually stenciled on the xfmr enclosure. If it is pole mounted the markings are usually large enough to be readable from the ground.That’s a pad mount style transformer. The actual name plate is on the inside of the low side door on the right. It is not on the outside. I
Lots of them are on the outside alsoThat’s a pad mount style transformer. The actual name plate is on the inside of the low side door on the right. It is not on the outside. If you are doing transformer calculations you also need %Z and the winding data and weights so might as well get the door information. Usually the tap changer and oil drain/sample port and all the gauges will be right there too. Once in a while I have found the oil sample port on the left side (high side).
The problem generally is access. On pad mounts owned by the utility they will often padlock it. Once past that the door bolt is often a 13/16” pentagon bolt head (utility socket). If you don’t have one you can often beat a 3/4” 12 point socket onto it. It is shocking how many utilities and plant maintenance groups that own these transformers don’t have utility sockets. Since it’s all low voltage though often the entire cabinet will be open with no divider between high and low.
