Jody Boehs
- Fairview, Oklahoma, USA
- Controls and Electrical Manager
Hello,
I am in the process of wiring a press brake that runs on 575V wired in Wye configuration. The shops power is 480V and it is also wired in Wye configuration. Therefore, a step-up transformer is needed. A previous electrician ordered one with primary voltage of 480V and secondary of 575V. But, it is a Delta-Wye transformer. Can this transformer be rewired on the primary side to work in this scenario?
I was thinking I could disconnect one lead on each winding and tie them together to create a Wye primary. Am I thinking right?
Also, it looks as though in a step-up transformer the connections are opposite. The H connections are secondary. And the X connections are primary. The reason I say this is because the nameplate on this particular transformer shows the X terminations are wired in Delta and the H terminations are wired in Wye. See nameplate below...
