akagie20
- Tempe, AZ, USA
I have a multitude of questions about the secondary short circuit current rating of a step-up transformer, but will try to ask them in separate posts for clarity.
Background: We had a custom transformer designed for us by a transformer manufacturer, which we now need to be tested by UL. UL wants to test the transformer first, and then our product with the transformer in it - we are actually just swapping out an existing custom transformer for a slightly different version of the same, but the transformer is not listed or recognized, hence the testing.
Transformer: It is a step-up transformer: 120VAC:3000VAC and 75 VA.
The problem: During the UL testing of the transformer, they have asked us what the SCCR (secondary short-circuit current rating) of the transformer is, because they have to test the transformer when the secondary is short circuited and measure the current at not more than 110% of the rated value (SCCR). I have asked our manufacturer for this information, but they do not know what it is.
Question: How does one determine the SCCR of a transformer?
I have found that one can calculate the secondary short-circuit current by determining the impedance percentage (Z%) and then use:
secondary short-circuit current = VA rating / (V-secondary x Z%), the transformer operates with single phase, 120 VAC, so no factor is needed.
In my case, the Z% has been measured at about 7.7% (I believe), the VA rating is 75 and the secondary voltage is 3000 V.
Therefore, my secondary short-circuit current = 75 / (3000 x 7.7%) = 325 mA.
At first I thought that this would also be the SCCR value, but I cannot find any information about how to determine the actual rating.
Thanks for any help you can provide.
