rhec boss 1
URGENT! I have been asked to comment about a proposed industrial installation in NC. There are upwards to 30 individual combination motor starter enclosures currently installed in this industrial environment. It has been proposed by the customer to bring each neutral from the individual combination motor starter enclosures to a central location including the overload trip contact, the run contact and coil wire to control it by a PLC. The customer then wants to tie all secondary grounded conductors (neutral) from each transformer to the new PLC control transformer grounded conductor. I have read myself in and out of it and need confirmation from someone. The NFPA-79 Electrical Standards for Industrial Machinery does not appear to answer the question. Reading in the NEC NFPA 70 Article 450.6 makes it sound like the customer can do this. I have never seen this done in the 27 years I've worked as an industrial electrician or as a project engineer. I have always removed the transformer at the individual combination motor starter enclosure and sent the new transformer 120 VAC source to the field enclosure with control wires to monitor, control and acknowledge operation from the new PLC control panel. Can anyone supply a reason citing NEC code or NFPA-79 article numbers for me to review?
[ July 22, 2005, 08:04 PM: Message edited by: rhec boss 1 ]
