Re: Transformer secondaries
It blows me away too!
Even the most simple minded Chimpanzee can see that a Conductive Metallic item will do just that when connected to a Circuit - Conduct Electricity!!!
No matter which way it's tooled, the fact still remains:
* There
_IS_ A Direct Electrical Connection between Primary and Secondary - and to me this very "Autotransformer-ish" now!
It will never be possible to claim - or draw a Schematic showing, solidly Grounded systems in a Structure not being directly and Physically Connected - when each system bonds to Metallic bodies (water pipes, structural steel, etc.).
Use a Typical 480Y/277 VAC 3?4W Service at a structure, then Ground it.
Star Point is Grounded, and Common Grounded Conductor runs out from Transformer Coils' Star Point.
Install a 480VAC Pri. ? 208Y/120VAC 3?4W Isolated Transformer - as usually done for 120V Power, and Ground it.
Star Point is once again Grounded, and Common Grounded Conductor runs out from Transformer Coils' Star Point.
Each of the Secondaries will also be bonded to any Metallic pipes or Structural items.
If this does not result in a direct connection of ACTIVE CIRCUIT CONDUCTORS, then please tell me whaddaheck am I doing in this Industry, fooling myself and others into thinking I have a shred of knowledge about Electrophysics!?!?!?
Yes they are Grounded, but so what! There's going to be a Potential Difference between the two Star Points, so what keeps this from resulting in a flow of Current?
As mentioned before, this is one of the Deadest Horses in Cyberspace!
Hot Files are still glowing from Months, and Years ago!
The funny thing is, if a Simpleton like Me can see it, why doesn't the CMP also see it?
OK, with that being said, all that I am doing here is tossing out the same old story, which we all have run through threads here since the first forum began! (what was that, like in 1997 or 98?).
No alliance or ridicule towards anyone - only the never been answered question of ...
Justwhaddaheckisgoingonhere!!!
Scott35
p.s. - edits for better sentences structure - they ended up trunicated after pasting the text back into this message body!
Me...Scott
This Message Was Sent From:
Scott E. Thompson / Thompson Electric
Via PC#5 (W/S P55C.LOC05.001)
E-Mail:
adst@pacbell.net
http://www.setelectric.electrical-contractor.net
Always Look For This "Sigfile" Or One Similar.
Definitions:
Control (CON-TROL) n.;
A Very Small Prisoner That Lives Under A Bridge.
Asset (*** -ETTE) n.;
A Little Donkey.
Ascot (*** -COTT) n.;
A Little Bed For Donkeys.
Naval Destroyer (NAYEE-VULE DEE-STROIE-EER) n.;
A Hula-Hoop With A Nail In It.
Trivia Question:
Q: What Makes The Tower Of Pisa Lean?
A: It Never Eats.
[ January 08, 2004, 01:06 AM: Message edited by: scott thompson ]
