Gategator37
A 7.2KV - 120/240volt 75KVA transformer is being installed by the utility. The engineer is showing 3-#3/0 conductors going from this Transformer to a 250 amp OCPD (Service Disconnect). I believe the engineer meant to say 2 parallel sets of #3/0 because #3/0 is only good to 200 amps. Now, to change this can one size the conductors from the transformer to the OCPD off of the OCPD size (250 amps) or do I have to size it based on the secondary amps of the transformer?
Thanks.
Thanks.
