Isaiah
- Baton Rouge
- Electrical Inspector
Client has an 300kVA power transformer, 3Ph 2400-480V (installed outdoors) with secondary conductors that terminate directly onto switchrack bus, i.e. "A" (primary windings are protected with a properly sized, fused disconnect switch). Switchrack A feeds a 100HP motor and a sub-switchrack, i.e. "B" that has a 200AT/250AF MCB protecting it. It seems the Xfmr secondary windings are protected per 450.3(A) but not sure about the xfmr secondary conductors per 240.21(C)(4).
