Transformer Secondary Disconnect, Interior Distribution
While not having my code book handy, back in the 80s I recall a rule that required a disconnect within 50 feet of the secondary of a transformer. Its a design practice I maintain, as it makes sense to have the ability to disconnect power on either side of a dry type transformer within a convenient distance of the transformer. Makes swapping out transformers easier if nothing else.
On the rule, I also recall the Durham NC Chief Elect Inspector (and then code panelist) carefully explain the rule was wire length and not horizontal length. As he stridently made us move the switches closer to the transformer on a fairly large exec center.
While the code does discuss primary protection where no secondary protection is used/required, secondary overcurrent protection is typically used We require it in all of our projects.
