I am having to add a transformer to a piece of equipment. The transformer is 3KVA, and will take 575V down to 230V. I will be powering three 1HP motors on the secondary. When I size the disconnect for the equipment, which also includes heater loads and compressors, should I use the FLA of the transformer primary (3000/575) or should I use the actual FLA's of the motors?
By the way, the motors fed by this transformer are all 1HP, and are not the largest motor inside the equipment.
If I used the Amp load of the motors on the transformer secondary, would I have to use the same ratio of 575/230 to calculate the amps being drawn on the primary? The amps would be reduced by that ratio going from secondary to primary.
