fluoronator
 - Alabama
 - Controls Tech
I have two spare transformers, one is a 15kva 480d to 240d/120ct, the other is a 9kva 480d to 120d. I need to power a 120v panelboard. Since only one coil of the 15kva is center-tapped, can I actually get more total current at 120v from the 9kva using all three phases than the center tapped 15kva?
Second question, if the 480d to 240d/120ct is only being used to supply 120v, does the third phase on the primary need to be connected?
