first thing, i'm not a expert on transformers, i took this job thinking the power company would supply the transformer ( 120/240 3phase) & do all the primary feed work to the property ( theres is a transformer 10 feet from property line which i figured the pc would come off the primary side and feed a new 120/240 3p transformer). after this morning meeting with the pc engineer at the job site, he said it would be easier if i did all the primary work ( come off the transformer secondary 480 volt & install my on 120/240 3 phase transformer on the property) this is what i'm going to install 200 amp 120/240 3 phase main breaker panel, from this panel i'll feed a 20 x 60 office trailor( thats all i know about it now) and a 240 volt 3phase 7.5 bandsaw. if i use the 200 amp to calculate my tran i'll need a 112500 va does that sound right,
after the meter ( 480 volts) i would have to hit a disconnect before the trans right? i was told i didn't have to. also if the 480 primary is a delta config i cannot get 120/240 only 120/208.
thank
don't have time to proof read my mesage hope every body understands
thank
