control Issues
I would like to correctly size a transformer for two 240VAC 3ph AC units.
Power available is 480VAC 3PH. The specs on the AC Unit only include the following:
Min. Amp Circuit 11.6A
Max Fuse Size 20A
RLA 8.4 (I assume Running Load Amps?)
No other details are avaialbe
I am assuming 11.6 is the FLA or full load amps.
11.6 X 1.25 X 2 = 29A (two compressor units)
3ph 15kw transformer at 240 provides 36A, 15000/240x1.73=apx 36A
I intend on using a 480/240 15KVA 3ph transformer. Is this correct?
Thanks in advance
Max Fuse Size 20A
Thanks in advance
