I need to size a 3 ph transformer to supply power to a 480 HVAC system. The primary of the xfmr is 208v and will be stepped up to 480. The name plate on the HVAC unit reads: FLA 36 amps, MIN CKT AMP 56 amps, both at 480volts. Which do I size the xfmr to? A 45kva xfmr would cover the FLA but not the minimum cicuits amps. Would the secondary overheat? Or is a 75kva the size which should be installed?
Thanks
Thanks
