ranger
- Washington
Today we had a discussion regarding transformer taps.One of our crews was working at a Wal Mart store.They wer'e supposed to wire a Xerox copy machine.The machine wanted to see 230 volts/not sure if it was 3 phase or 230 plus neutral.Anyway their closest/most reasonable power source was 3 phase 208.So the machine tech set the machine to run at 208 internally.The problem was that the source kicked out 200 volts which the tech said put the machine's voltage out of tolerance.The discussion went that the input voltage needs to be measured and that it may be possible to change the transformer taps in such a way as to bring the voltage up into acceptable limits.They have a rule i guess about using buck-boost transformers.My question is this does anyone know how to use the different taps on the transformer?Even if someone could point me in the right direction to learn more about this it would be helpful to me .Thanks P.S apparantly this machine was over 100K$ no room for error!!
