FrancisDoody
- Durham, CT
This is a question that was presented on a Journeyman's exam this week. The question never mention the primary or the secondary, It simply said that a transformer has 1.25 volts per turn. There are 192 turns. So the first thing someone would do is multiply 1.25 times 192 and the answer is 240 volts. Well there it is right next to the letter C. So you circle it and move on. Well after finishing the test you start your review and this question pops up again. That answer is to straight forward for a test. A transformer has a ratio. Most are 2:1. So if the primary is 240 volts and the ratio is 2:1 the answer would be 120 volts. 120 volts happened to be answer B. The trouble is that with such limited information you will never be able to agree on the correct answer. There is no way to ask the state for the answer unless you fail the test and sit for a review. So I quess we will never know. Has anyone else had that same question from the ocean state.
Thanks,
Fran
Thanks,
Fran
