transformer wanted
Toros
Tujunga, CA
Is it easy to find , or better say "is there such thing as tranformer with set up of ; 240v,3ph. primary to 480v , 3ph. Wye secondary? i know that i have to make a neutral at wye secondary by grounding any phase od 2ndy @ corner but is not required (sorry)
I have no idea what the 2nd part of post is stating, but a 240 3 phase to 480/277 wye is a common transformer. On the secondary (480/277) side you would ground the 277 v neutral terminal.
Depends a lot on the type transformer you are looking for.
Commercial/Industrial "standard" step-up/step-down/buck& boost here's one of many links:
http://www.acmetransformer.com/en
GE & SquareD catalogs are full of all types.
