I have a 277/ 480 vac Wye supply feeding a 15kva, 480 delta primary to a 400 vac wye secondary. This transformer will supply a 400 vac 3 phase machine. My question is for the 400 vac wye secondary. When I bond the xo tap to ground, I will not need to run a neutral to the machine correct? I will run a equipment ground the machine for ground fault protection.
