We had a project where the specs called for us to use crimp lugs on all the transformer connections. The transformer XO port had predrilled holes to be able to bolt two lugs to the XO terminal. We had parallel neutral conductors and a system bonding jumper attached to the ground bar. We attached the GEC to the ground bar. We used two straight lugs and one stacking lug. The inspector said that lug had to be a 3 barrel one piece lug. He also said that lug could not have any extra terminals say a 4 barrel using only 3 lugs. He said the parallel conductors connected to X1,X2 and X3 with the 2 crimp lugs were fine. My electrician did it the way the inspector requested to get the inspection but I can't seem to find this in the code.
