Smash
- Philadelphia suburbs, PA USA
I know this topic has been discussed at length and I finally maybe I think understand the bonding and grounding of transformers in general. Some of the different exceptions and scenarios can still be confusing. My problem or question I’m hooking up a large saw from China I mean really from China not just made there. The manual, controls, everything Chinese. It’s Designed to run at 200V 3phase I’m installing a 3phase 45KVA 480V/277V to 208/120 transformer. Saw rep said quote“208 very good “ Did all the calculations 70Amp breaker on the primary side 125amp fusable disconnect on the secondary side. There is 3 lines and a equipment ground on the primary side EG on a lug at the service entrance. I pulled 5 total lines from the secondary to my disconnect. X1 X2 X3 X0 neutral and a #2 ground wire which I fed thru XO to aid as my bonding jumper and terminated at the ground lug I installed on the transformer metal frame. Here’s my question inside the saw which arrived last night after all other work is done there are only four terminals L1 L2 L3 and PE which is used as green ground then jumps to terminal block for all control grounds for the machine. There is no neutral do I need to use the XO terminal at all do I carry it through to the unit and terminate it at the machine ? I’m just not sure which I should be using. Right now I’m using both through the disconnect with no where to terminate my last 5th wire in the saw. I also have both on the combination block in the disconnect with the bonding screw intstalled. ( I know that needs to come out to keep a fault traveling back to the source) Is XO even needed ? If not I just continue the EGC straight from the source to the machine bonding transformer and disconnect along the way. Clear fault path machine to source. Is a bonding jumper still required at XO in this case. My brain hurts
